Activity Forums Apple Final Cut Pro Legacy quick question—
  • quick question—
    Posted by Rick Neely on January 19, 2007 at 5:48 pm
    minor problem but something I wasn’t sure if I can do. Am doing a project where I assemble 6 seperate sequnces that will eventually be played simultaneously. I’m tring to make a matrx preview for a client, dragging the six sequence s into a seventh one, rescaling the size so they can be viewed as two rows of three. Even after a full render it appears the machine can’t play them. They just hold on the current frame. I’m using a quad mac g5 with aja io. Have I hit a buffer limit or something? Any other ideas to resolve? thanks.
    Rick
    Rick Neely replied 19 years, 8 months ago 4 Members · 5 Replies
  • Captain Mench
    January 19, 2007 at 5:57 pm
    Odd…
    I’d check the normal things…
    View – External Video – OFF or ALL FRAMES if you are going to an external monitor…
    Check the size of the canvas — make sure it’s set to FIT TO WINDOW…
    Dbl check the sequence settings and make sure they’re still something normal… DV/NTSC or whatever.
    IS this DV? HD? HDV???
    Hmmmm
    CaptM
  • Shane Ross
    January 19, 2007 at 6:25 pm
    Also, what drive is the media stored on? It might not be fast enough to play back 6 streams of video. FW40, for example, cannot do this.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Captain Mench
    January 19, 2007 at 7:09 pm
    Ah — good point. The media isn’t on your system drive either, right? — render scratch too. I’ve been at fault after installing FCP to forget to change the scratch and have it default to my Documents folder!!
    CaptM
  • Jeremy Garchow
    January 19, 2007 at 8:05 pm
    Yeah, but after it’s rendered, the video is now just one flattened video stream.
    I think Mench it it on the head, your new sequence is not matching your output settings. What settings is your newly rendered sequence set at (hit command-zero to being up the settings) and what settings are the original sequences set at?
    Jeremy
  • Rick Neely
    January 19, 2007 at 11:29 pm
    Thank you all,
    don’t know I was getting fits. I just trashed settings restarted, rendered and poof! We’re fine. I probably would have just done this anyway but I had a client calling every 5 minutes and I got worried initially that rebooting would add to the problem. Thank you all for your help again!
    Rick
