Activity Forums Apple Final Cut Pro Legacy quick, hi-quality previews?
  • quick, hi-quality previews?
    Posted by J. Tad newberry on August 6, 2007 at 10:58 pm
    my Mac has been rendering most of the day, so i can send my client some 800kbps H.264 files to preview a project. there are four segments (about 5-6 minutes each) and each one is taking almost 2 hours to render at this setting. also, these rendering the single movie files i had made of the actual timelines, which seems to be quite a bit quicker than rendering the H.264 from the whole (un-rendered) project sequence timeline.
    i’m guessing the best answer here is to NOT do 800kpbs, but something smaller? any other ideas for quicker renders of this sort?
    thanks again!
    mh
    David Roth weiss replied 19 years, 1 month ago 3 Members · 2 Replies
  • Jeremy Garchow
    August 6, 2007 at 11:00 pm
    Use Sorensen 3 instead of the processor intensive h264.
    If you have a MacPro and compressor 3 (FCS2) you can setup a virtual cluster in your machine to render faster and utilize those 8 cores.
    Jeremy
  • David Roth weiss
    August 6, 2007 at 11:03 pm
    H-264 is notoriously slow. Try Sorenson 3. If you are deinterlacing and/or changing the aspect ratio that will also add lots of time to your renders.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
