Activity › Forums › Apple Final Cut Pro Legacy › Quick Help needed. Compressor MPG2 audio issue
  • Quick Help needed. Compressor MPG2 audio issue
    Posted by Ernie Santella on June 22, 2009 at 4:05 pm
    Help guys. (In a rush)
    I’m trying to compress a FCP timeline to MPEG2 for a cable system upload. I’m using a FCP-Export (Reference) file. Import into Compressor, use the MPEG2 preset, changed it to their video specs. They say the video is fine, but the audio is muffled and compressed?
    Do you guys have any suggestions on setting for the audio? Compressor doesn’t give many options. Only Peak limiter and Dynamic Range. I left them at their presets.
    Thanks in advance.
    Rafael Amador replied 17 years, 3 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    June 22, 2009 at 5:32 pm
    I’d think you want to finish your audio in FCP or Soundtrack Pro, and if needed, use the filters there first. Then your compressed audio should sound much the same.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Ernie Santella
    June 22, 2009 at 5:36 pm
    I am finishing in FCP. It’s a very simple soundtrack V/O and a music bed. Couldn’t be simplier. It sounds great in FCP. (I have a very high-end audio system (VTL Tube amps, Tannoy DMT-12″ pro studio monitors)
    I even checked the MPEG 2 file after Compressor and it sounds fine. Not sure what the heck the kids at Comcast are hearing that they say it sounds compressed?
    Do you guys change any of the Compressor settings when encoding for MPG2 Program Stream?
    I’m baffled.
  • Rafael Amador
    June 22, 2009 at 5:55 pm
    Arnie,
    Compressor do not offer options for the MP2 Audio. I think that it sticks with the old standard 224Kbps.
    You may try to make the .m2v in Compressor and then “BitVice Helper” or “ffmgx” to make the MP2 and mux video and audio.
    You can rise the audio data rate with those applications.
    rafael
    http://www.nagavideo.com
