Activity › Forums › Panasonic Cameras › Quick help and opinions on dvx 100a vs. dvx 100b….which to buy?
  • Quick help and opinions on dvx 100a vs. dvx 100b….which to buy?
    Posted by Josh J. johnson on February 13, 2007 at 5:27 am
    I have two deals right now from trusted sellers (people I know) dvx 100a 29hours of use for 1,800 with Panasonic shotgun mic and extra battery 5400mah or dvx 100b for 2,325 1 hour of use with manufacture warranty unregistered, new 72mm Tiffen UV Filter, fire wire cable, and that book and dvd the camera comes with.
    How do these two differ from compatibility with avid? What do you guys think is the better deal?
    I already have a 8,200 hp workstation 4 gig ram.
    Deleted User replied 19 years, 7 months ago 3 Members · 3 Replies
  • Deleted User
    February 13, 2007 at 2:28 pm
    get the b qith lower mileage and it has a few better options
  • Tim Scarpino
    February 13, 2007 at 3:58 pm
    I don’t believe there is any compatibility issue with Avid for either of these units, though many recommend using a different DV deck to capture material. DV capture using firewire is OK, though responsiveness is better with a deck than the camera.
    If you’re using an Avid Recommened Setup, you should be fine.
    Tim Scarpino
  • Deleted User
    February 13, 2007 at 8:19 pm
    what is a DV deck? Where can you get them from? (the best quality) Thanks
