Quick Effect prob
i have just started working on avid xpress pro 5 hd and i am facing a problem initially while apllying effects through quick transition. while opening the dialouge box i cant add affect as default setting show 0 value in both the options and when i try changing the value it keeps on being 0 only. actually i am applying the effect between two still pictures .
please tell me a solution
help will be appreciated.
