Activity › Forums › Avid Media Composer › quick cuts editing
  • quick cuts editing
    Posted by Joe Carey on February 3, 2010 at 10:11 pm
    I’m doing a timelapse video of a building under construction. I have hundreds and hundreds of digital still photographs that I want to insert at .5 sec intervals. Is there an easy, efficient way to do this?
    Justin Gray replied 16 years, 8 months ago 2 Members · 1 Reply
  • Justin Gray
    February 3, 2010 at 10:36 pm
    In you import settings under the image category set you Frame Import Duration to .5 secs. Hopefully your frames are numbered sequentially. Import into bun. Right click “name” in bin and select …”Sort Ascending.” Select all clips and drag into timeline. Voila!
    – Justin Gray
    KLTV Promotions
