Activity Forums Apple Final Cut Pro Legacy Questions regarding using RAID and separate Cache disk
  • Questions regarding using RAID and separate Cache disk
    Posted by Xavier De champs on October 29, 2009 at 2:44 pm
    Hi. I’m planning to be editing some HD footage on my new Mac Pro. I have installed 5 hard drives. The fifth one is installed underneath the optical drive, and number 1 – 4 are installed in the bays, running with a Mac Hardware Raid card.
    I am planning on running like this:
    Bay 1: System Disk OSX (not RAIDED)
    Bay 2 – 4: Video footage disks (RAID 0 or RAID 5)
    Fifth drive: Cache disk for photoshop and FCP and After Effects
    My question is regarding the Cache disk. Is it a good idea to run like I’ve set it up? Or would it be better to put OSX on the fifth drive (under the optical bay), and then run all the bay-drives in RAID 0 or RAID 5 with both video footage AND cache on this raid-array?
    In short: Will the cache disk run better as a standalone or on a raid-array sharing with video footage files.
    Jeremy Garchow replied 16 years, 10 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    October 29, 2009 at 3:13 pm
    [Xavier de Champs] “Or would it be better to put OSX on the fifth drive (under the optical bay), and then run all the bay-drives in RAID 0 or RAID 5 with both video footage AND cache on this raid-array? “
    Yes. Put the cache on a fast disk, along with all your other media. No need to make a separate disk for it.
    Jeremy
