Activity › Forums › Adobe After Effects › Question on Dan Ebberts Engine Animation Tutorial
  • Frank Thomas
    January 2, 2008 at 3:10 am
    As I’m not familiar with that particular tutorial, I can’t help with the piston problem.
    I did, however, notice another small problem (which you can easily fix). One corner of the counter-balance on the cam is overlapping the sides of the piston cylinder.
  • Josh J. johnson
    January 4, 2008 at 5:11 am
    Thanks Frank I fixed it :).
