Activity Forums Adobe After Effects Question on Auto-tracing
  • Question on Auto-tracing
    Posted by Stanley Flomin on May 11, 2009 at 7:50 pm
    I have a brush stroke that I’d like to auto trace, my issue however is that auto trace always seems to only make a ‘full circle’. So if i have a horizontal line….it will go all around it, however, what I need is a single non-complete mask. Meaning, a point at the bottom of the horizontal line and a point on top rather then one on each corner. Is it possible to do that?
    Reason I ask is because I have complicated brush strokes i’d like to auto trace but i *need* a single line through the entire stroke rather then the stroke ‘around’ the whole thing. I’m applying 3d stroke from trapcode on these lines and animating the ‘start’ to ‘end’ stroking, but it looks bad because it has to stroke AROUND the objects rather then ‘through’ them…
    I’m certain I could have done a better job explaining but hopefully its still understandable….
    many thanks in advance
    Stanley Flomin replied 17 years, 3 months ago 2 Members · 2 Replies
  • Dino Muhic
    May 12, 2009 at 12:25 pm
    This is not possible with Auto-Trace, because it’s meant to trace the outlines of an object.
    In your case I would just paint the mask on my own. It’s 2 clicks to draw the mask and it’s more than two clicks to apply the tracing to the layer and testing around. You could have done it by now 😉
    Cheers
    Dino Muhic – Media Producer
    VFX – Motion Graphics – Web-Design – Or just ART
    http://www.dinomuhic.com
  • Stanley Flomin
    May 12, 2009 at 1:42 pm
    I know it would have been faster to draw the mask for a rectangle….but I just used that as an example, unfortunately I have far more complicated shapes, and a ton of them.
