Activity › Forums › Adobe After Effects › Question on animating a signature Tutorial
Posted by Tomsmall on April 12, 2005 at 4:25 pmi know many of you are familiar with this tutorial. my question is, can it be done with in completely within AE 6.5 Pro? or do you still have to use illustrator?
Tom
Steve Roberts replied 21 years, 5 months ago 4 Members · 6 Replies -
Steve Roberts
April 12, 2005 at 4:32 pmSignatures can be done by using AE’s pen tool to draw open masks that match the signature. Next, you apply the render>stroke effect, set to “all masks” and “stroke sequentially”. To make it write on, you animate the stroke’s end value.
There you go.
Steve
Tomsmall
April 13, 2005 at 2:11 amThanks alot steve! and one thing i discovered myself if anyone else uses thing effect, in the effects controls for “effects > render > stroke” is that the “paint style” parameter needs to be set to reveal orignial image or else it just paints a colored line over your text. Thanks again steve!
Tom
Scottie
April 13, 2005 at 2:55 pmBeen trying to figure out an easy way to do that for months…thanks to you both for your help!
Steve Roberts
April 13, 2005 at 3:10 pmNo, I run my own little thing. But I have met Tim Martin at Framblender. Nice fellow.
S.
