Activity Forums Blackmagic Design question for Kristian
  • question for Kristian
    Posted by J on May 29, 2006 at 8:02 pm
    Kristian
    i have a few questions for the decklink extreme for pci-e on a quad g5 going to a sony ntsc broadcastmonitor.
    im newer to the black magic set up and i have installed everything but i am wondering the connection config to the ntsc
    the correct set up i know i can get video out i tested the connection with the 10 y bnc and i was not sure if i had the set up correct just to go into the line in on channel a .
    if you or anyone else has some tips it would be great thanks
    oh yeah running 10.4.6/fcp 5.0.4/qt pro 7.0.1 on quad g5
    Kristian Lam replied 20 years, 3 months ago 2 Members · 1 Reply
  • Kristian Lam
    May 30, 2006 at 1:33 am
    Wat you’re doing sounds right. If you’re monitoring just composite video, se the Y output from the card and send that into the Line A of your monitor. You should also switch the output options in the DeckLink preferences to “NTSC / PAL (Y Out)”.
    regards
    Kristian Lam
    Blackmagic Design
