Activity Forums Blackmagic Design Question: Decklink Studio SD/HD Powering Multiple Monitors?
  • Question: Decklink Studio SD/HD Powering Multiple Monitors?
    Posted by Remsy Atassi on October 27, 2011 at 4:58 pm
    My company is moving to a new facility and upgrading some of our setup.
    We want to be able to do a few things…
    1. We want to be able to feed HD picture to two monitors simultaneously – one in the booth, one in the control room. Could I run both feeds using a Decklink Studio or would I need to split the output out of the box. What would you recommend as a DA in this case? Should I be concerned about quality loss from long cable runs?
    2. In the audio booths we want to have a WebCam+Skype monitor setup that is running from computers in the control room. Is there a way I could control this switching on the same monitor, or would I need another? Would this interface with a the Decklink or is there a better solution?
    Remsy Atassi replied 14 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
