Activity › Forums › Adobe Illustrator › Question about window illustrator
  • Question about window illustrator
    Posted by Hannah Benbow on January 31, 2011 at 1:28 am
    How do I get the window to go back to normal? It’s stuck under the top part. I know photoshop has a button that you can just make it fit back to screen, but I can’t find it on illustrator.
    Here’s what I mean.
    And this is what I want back
    David Cabestany replied 15 years, 7 months ago 2 Members · 1 Reply
  • David Cabestany
    February 4, 2011 at 10:21 pm
    the shortcut is the same as photoshop, the letter F, it cycles between window with top header and top menu, top menu w/o top header and full screen w/o top header and top menu.
    also you can try hitting Tab so you hide al your panels, including the control panel which is the one hiding the top of your window, after that you can just drag it down.
