Activity › Forums › Adobe After Effects › Question about superblacks and superwhites in AE 5.5
  • Question about superblacks and superwhites in AE 5.5
    Posted by Bill Ravens on August 8, 2011 at 1:15 pm
    I’ve tried to search for an answer to this, but, it seems to be such a huge source of confusion that I can’t understand what I’ve read.
    My question relates to the color space used within AE 5.5. When bringing a Sony MXF file into AE, it is tagged with the YCrCb color space.I’ve imported a REC709 Color Bar pattern with pluge bars. No matter what I do, AE clips the pluge bars below 0%. If I import the same REC709 color bar pattern in to Media Composer, I can perform a CC to recover the super blacks. Because AE clips the superblacks when I import, I can’t recover the shadow detail info.Even if I check “Preserve RGB” the superblack values are clipped.
    Is there a way around clipping superblack and superwhite values?
    edit: it would appear AE maps the imported color bars to RGB0-255, clipping values below zero and above 255. Media Composer imports the same color bars to RGB16-235, allowing access to the superblacks and whites.
    Bill Ravens replied 15 years, 1 month ago 2 Members · 4 Replies
  • Darby Edelen
    August 8, 2011 at 8:34 pm
    Are you working in a project that is set to a 32bpc color depth?
    Darby Edelen
  • Bill Ravens
    August 9, 2011 at 4:11 am
    no, this is a standard 8-bit.
  • Darby Edelen
    August 9, 2011 at 4:44 am
    [Bill Ravens] “no, this is a standard 8-bit.”
    Touché, I should’ve phrased that differently: You should try working in 32bpc.
    Darby Edelen
  • Bill Ravens
    August 9, 2011 at 12:12 pm
    AHAH!
    Many thanx, Darby! I’m not a wise-axx…just thickheaded, sometimes. That worked.
