Activity Forums Apple Final Cut Pro Legacy Question about sequence’s “uniqueness”
  • Question about sequence’s “uniqueness”
    Posted by Diego Massanti on May 19, 2009 at 10:35 am
    Hi there, i have a certainly basic question i think….
    When i create a sequence that i use several times inside a big project (for example the animated background for a lower third) why is that if I at a later time modify the “master” sequence for it, the ones inside my main timeline seems to ignore the changes ???
    Are sequences in FCP independent ?
    Could anybody clarify on this issue ?
    Thanks in advance, Diego.
    Cheers.
    Diego Massanti.
    Tal Rom replied 17 years, 4 months ago 7 Members · 9 Replies
  • 9 Replies
  • Walter Biscardi
    May 19, 2009 at 12:28 pm
    [Diego Massanti] “Are sequences in FCP independent ? “
    Yep. For the most part. When you Nest a Sequence you should be able to change the master sequence and it will change everything else you’ve included that Nest in. But it doesn’t always work.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Diego Massanti
    May 19, 2009 at 12:32 pm
    ” But it doesn’t always work…”
    Well… it is never working for me, this is really frustrating… what kind of editing behavior is this ?
    I am certainly new to FCP (come from avid), and honestly im speechless about this issue…
    Cheers.
    Diego Massanti.
  • Bob Flood
    May 19, 2009 at 1:58 pm
    Diego
    FCP is not avid, so be prepared for it to act differently
    FWIW nested sequences seem to remain linked to each master sequence individually, such that if I have a Nested seq in Show Version 1, adn make a copy of that show, i have now made a copy of Nested sequence 1 as well. so by double clicking my nest in Show Version 1, I WONT be accessing the nest with the same name in the copy of show version 1
    waht does this all mean?
    If you want to make a nest and have changes to that nest appear in multiple iterations, open the nest from the browser, export it as a native quicktime, and cut it into your show in place of the nested sequence.
    If you change the nested sequence, re export it, and replace the older export at the Finder level, it will change all the copies of that export in your project
    hope this helps
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
  • John Fishback
    May 19, 2009 at 2:34 pm
    It might be easier to do create those kinds of elements in Motion so updates would happen “instantly” after you save changes to your Motion project.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Diego Massanti
    May 19, 2009 at 2:41 pm
    Yah well i totally understand your idea here, but im kinda confused now, i never expected a professional level editing app to behave like this, i guess im going to perform some more investigation before blaming more :p
    Cheers.
    Diego Massanti.
  • Diego Massanti
    May 19, 2009 at 2:48 pm
    Yah well John, big issue here is that i use AE 🙂
    Cheers.
    Diego Massanti.
  • Chris Poisson
    May 19, 2009 at 3:09 pm
    Diego,
    There are two ways to duplicate sequences in FCP. Copy and paste or use the Duplicate function. The first way retains a parent/child relationship and the second makes an entirely independent sequence.
    Have a wonderful day.
  • John Pale
    May 19, 2009 at 3:42 pm
    Actually this is similar to the way it works in Avid. If you duplicate a sequence on Avid it becomes independent, and if you edit a sequnce into another sequence and then change the original it does not update either.
  • Tal Rom
    May 19, 2009 at 5:57 pm
    FCP update ONLY!! sequences the you didn’t change in any parameter.
    So, if you trim the In/Out points
    or if there is clip that prevent the sequence from change duration
    it will be no change and you nested sequence will be “Version” of the original sequence.
    Tal Rom
    PrePost
    Production & Post Workflow Solution
    Israel
