Activity Forums Adobe After Effects Question About Pipeline After Effects
  • Question About Pipeline After Effects
    Posted by Ángel Molina lópez on February 16, 2019 at 11:35 am
    Hi everybody,
    I want to make an animation, teaching series that will be formed by two parts: an 8 bits animation with some characters hosting the program and some motion graphics that will illustrate the content which the characters are explaining. Right now, I have the 8 bits animation and the motion graphics separated in two AE projects but I will use transitions to move from one part to another. My question is the next one: should I merge both projects into one to use the transitions without any problems? Or should I render the projects separately, put them into a video editor and place the transitions in it? The problem is that some transitions affect DIRECTLY the video . It’s not a separate animation that you can set as an alpha or as another layer. What is the standard procedure in these cases?
    Regards.
    Kevin Camin replied 7 years, 6 months ago 2 Members · 1 Reply
  • Kevin Camin
    February 19, 2019 at 6:21 am
    To me it sounds like the animation and motion graphics are going to be mostly original the entire time. I would merge the two projects so you can easily retime things. I don’t think there’s any time saving by dynamically linking things in Premiere, they still have to render since they are After Effects comps. I feel you are sort of adding a step by moving what essentially is an animation to Premiere. But if you have live action footage and the animation and motion graphics are secondary then I would do it in Premiere.
    Best regards,
    Kevin Camin
