Activity Forums Apple Final Cut Pro Legacy Question about mixing footage w/ different frame rates, codecs…
  • Question about mixing footage w/ different frame rates, codecs…
    Posted by Edward Calabig on May 24, 2008 at 8:20 pm
    I was wondering which Final Cut I need to mix footage with different frame rates and codecs. I’m being asked to create a project from footage taken from different cameras, dvds/cds, and aspect ratios. Is this possible? If so, what do I need? Anything I need to keep in mind?
    If at all possible, I would like to perform this in FCP5.1.
    Thanks.
    Edward Calabig replied 18 years, 4 months ago 2 Members · 2 Replies
  • Nick Meyers
    May 25, 2008 at 3:31 am
    switching to FCP6 will make this a lot easier.
    yes you can do it in 5.1, but you’ll get much clunkier playback.
    should not that neither 5 or 6 do good frame rate conversion.
    it;s just simple dropping or duplication of frames.
    the nattress standards conversion plugin, or compressor will do a better job.
    nick
  • Edward Calabig
    May 25, 2008 at 5:35 am
    So what should my workflow look like?
    Do I import all the footage at the same codec or at their native ones? Then do I convert using some program, then begin editing? Sorry I’m new to mixing footage.
