Activity Forums VEGAS Pro Question about how to render
  • Question about how to render
    Posted by Cosmo Kramer on July 23, 2006 at 2:55 pm
    Ok I have a video that is about 2 mins long that I am sumiting a video to a contest online. And the file size has to be 100mb, is there any way to control the size of the video, like change the resolution.
    Jeremy Rochefort replied 20 years, 1 month ago 3 Members · 2 Replies
  • Jlopez
    July 23, 2006 at 5:34 pm
    if its xvid or mp4 – you can set your bitrate to a specific number to make your file smaller or larger. the quality will change accordingly. a bitrate calculater will help you determine your final size. i cant find it now – of course- but under certain conditions you can set your final output size as well as variable size- its all under the render as- template- custom – video- settings
  • Jeremy Rochefort
    July 23, 2006 at 6:54 pm
    Here is a calculator to determine your output size:
    Calculator
    Jeremy
    MJ Productions
    MJ Productions
