Activity Forums Adobe After Effects question about expression on the scale transform
  • question about expression on the scale transform
    Posted by Kathyb on October 29, 2005 at 3:42 pm
    Hi. I am new to After Effects and I am learning about expressions. I added an expression to the scale transfom on my first layer. I use the pick whip to link it to the rotation transform on my second layer. Can anyone tell me if there is a way to add an expression only to the y axis of the scale transfom on my first layer?
    Thank you!
    Kathyb replied 20 years, 11 months ago 2 Members · 2 Replies
  • Colin Braley
    October 29, 2005 at 5:15 pm
    Try this:
    s = thisComp.layer(“Second Layer”);
    [value[0], s.rotation]
    What this does is basiacly say create a variable named s that is the layer in the comp called second layer. Then set the Y scale of the current layer to the rotation of the layer “Second Layer.” This expression leaves the x component of the scale as is. If you want to learn more about this kind of stuff check out http://www.motionscript.com
    ~Colin
  • Kathyb
    October 29, 2005 at 8:12 pm
    Thanks so much. It worked!
