Activity › Forums › Apple Final Cut Pro Legacy › Question about exporting XML
  • Question about exporting XML
    Posted by Chris Jones on May 3, 2012 at 6:42 pm
    (I posted this under the Davini forum originally – but thought maybe the problem I’m having might be what I’m doing (or not doing) in FCP)
    This is what I’m trying to do:
    1) Create proxy ProRes files in Resolve from original DPX files.
    a. [In Resolve] I’m using Scene Detection to split 5 min DPX clips into the different takes within the clip and doing a simple grade for each take.
    b. I’m then Rendering out ProRes files for each of the split takes to a new folder.
    2) I am then renaming the new clips(files) to its Scene-Shot-Take name: For example: from 164884 to 48C_01_01
    3) [Then in FCP7] I’m editing the shots and exporting an XML.
    4) [Then back in Resolve] I’m trying to import the original DPX source files for final grading.
    But this is what is happening:
    When I load the XML and navigate to the folder with the source DXP files Resolve tells me all the newly named files can’t be found.
    I thought XML linked to the Timecode? I figured as long as I navigated Resolve to the correct folder. It would find the correct timecode and load the correct DPX.
    Thanks in advance for any help with this.
    Andreas Kiel replied 14 years, 4 months ago 2 Members · 1 Reply
  • Andreas Kiel
    May 5, 2012 at 1:51 pm
    There is no real timecode in FCP XML rather then for the original files.
    There is is a link to the source files which is in your case the most important one.
    Spherico
    https://www.spherico.com/filmtools
