Activity › Forums › Adobe Premiere Pro › Question about Archiving – using Prelude
  • Question about Archiving – using Prelude
    Posted by Carolyn Moreau on November 20, 2012 at 2:35 am
    Sorry if I am posting this in the wrong forum. The background to my question is that I work for a university and my employer wants me to create a library of stock video clips – like classroom footage, scientific research etc.
    I’m using Prelude to quickly export stock clips to a folder on my desktop. It will then be uploaded to Extensis. I’m aware of the whole issue with metadata as a sidecar not working with Extensis.
    But my questions is would it be better to export these clips as xmp op1a – which as I understand is a platform agnostic wrapper for XDcam footage? Or should I archive these clips as ProRes? We’re editing with Adobe and I don’t see us ever going back to Final Cut. I’d like to give my employer an archive that is going to useable far into the future and has enough metadata so that it doesn’t rely on having employees with memories of what was shot when.
    Thanks for any advice.
    – Carolyn
    Angelo Lorenzo replied 13 years, 10 months ago 2 Members · 1 Reply
  • Angelo Lorenzo
    November 20, 2012 at 4:48 am
    It’s really subjective. If you’re working within a limited set of frame sizes and frame rates, I would probably go XDCAM.
    ProRes:
    Less aggressive compression
    No practical limit on frame size
    No practical limit on frame rate
    Single vendor video codec (con)
    Single vendor container (con)
    XDCAM:
    MPEG-2 4:2:2 @ 50mbps
    Limited frame sizes (con)
    Limited frame rates (con)
    Slightly more aggressive compression (there are online comparisons, and the differences are slight)
    Multi-vendor video codec, SMPTE standard MXF container
    https://www.freshdv.com/2011/05/f3-xdcam-vs-prores.html
    Angelo Lorenzo
    Love my answer? Do me a huge favor and check out my Kickstarter project The Librarian, starring Jennie Garth of Beverly Hills 90210.
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
