Activity Forums Adobe Premiere Pro question
  • Posted by Doug Shoha on February 18, 2006 at 7:13 am
    Has anyone out there noticed that in premiere 6, tyou and import in quicktime, animation, millions plus, and its great for greenscreening, but in premiere 7 you cant import this way, and if you convert it, you lose the advantage? I do screening all the time and its always a struggle now, anyone else notice this?
    Artworkswme.com
    Doug Shoha replied 20 years, 6 months ago 2 Members · 2 Replies
  • Craig Howard
    February 19, 2006 at 7:56 am
    millions+ means the clip has an alpha channel and therefore does not require a green screen (chroma key). No reason why it would not work in Prem 7 (1.5) or 2.0
    Works for me.
  • Doug Shoha
    February 20, 2006 at 4:46 am
    Hi craig,
    thanks for responding. I understand it has an alpha channel, and I use greenscreen because I am actually using commotion pro’s primatte keyer, and it works wonderfully, the thing I was addressing, is the fact that prmiere pro doesnt let u capture in quick, anim plus, its like they took it out, unless I am missing it, however I just read that 2.0 they put it back in.
    I have experienced a difference capturing in any other format and then converting it, with the same clips run on 6 and 7.
    capturing it differently was giving me diagonals thet were more pickey.
    p.s. I used commotion because i didnt have a full greenscreen and had to roto our the edges ect
    Artworkswme.com
