Activity Forums Adobe After Effects Quest for Neg spotting software – how does AE work with multibridge extreme
  • Quest for Neg spotting software – how does AE work with multibridge extreme
    Posted by Justin Tan on February 18, 2006 at 11:43 am
    Hi all,
    not sure if you have seen my various threads throughout creative cow, but one of the key things I have been working on is finding a neg spotting solution for 10bit HD 444 footage.
    I am using a multibridge extreme in my G5 and can play RT in FCP.
    I read that the MB Extreme supports AE, so if I export a clip out of FCP in black magics codec, can I assume that it will play real time in AE?
    if the above is true, then can someone recommend a good neg spotting plugin for AE? This is how I would like to work…
    option A, find neg spot/scratch, select which source (most likely the same as that being neg spotted), and then which frame in that source (usually before or after, but if possible others as well), “mark/erase negspot”. – this is how it works in FLAME/SMOKE.
    option B is to clone
    The most important thing is that I can paint per frame as oppose to key framing and that it works in 10bit plus.
    I know of silhouette paint, but I am not 100% sure that you can select which frame you want to use as the source, you can only set a global offset…
    would appreciate any advice to help me get rid of this headache…
    Justin Tan replied 20 years, 6 months ago 2 Members · 2 Replies
  • Paul Miller
    February 18, 2006 at 3:36 pm
    In Silhouette you can specify any combination of clone sources – it can be a relative offset from the current frame or a fixed frame, and you can paint from the current clip or a different clip – even the painted or unpainted version.
    But, as I mentioned in another thread, FCP has a bug that prevents 10 bit codecs from working in certain AE plugins.
  • Justin Tan
    February 18, 2006 at 10:54 pm
    thx Paul, looks like i have to give paint another go – under AE this time…
    if only it didnt take you out of AE…but ATM looks like it’s the forerunner – just need to test and convince others to purchase…
