Activity Forums Adobe After Effects Quality not full
  • Quality not full
    Posted by Marcelokron on May 12, 2006 at 10:58 pm
    Hi guys… I have AF 6.5. All my quality settings are in best position… on the time line on the comp monitor window etc.. but I still seeing some artifacts in image specially in inclined objects. I just see full quality after making a movie and exporting to premiere…
    This is normal??
    Thanks any help!!
    Steve Roberts replied 20 years, 4 months ago 6 Members · 8 Replies
  • 8 Replies
  • Justin Productions
    May 13, 2006 at 1:49 am
    What are your render settings in the Output Module (guessing you’re rendering by “Make Movie”).
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.0 Professional
  • Marcelokron
    May 13, 2006 at 3:43 am
    My out put is OK I’m outputting Microsoft Dv NTSC… but in my comp window I’m not getting full resolution…
  • Marcelokron
    May 13, 2006 at 3:55 am
    you guys can see all settings are in best and I getting this problems were I made green circles…
    link with print screen jpg: http://www.marcelokron.com.br/after.jpg
  • Julian Sixx
    May 13, 2006 at 4:37 am
    Hi
    i guess it’s a field problem.
  • Mike Smith
    May 13, 2006 at 6:40 am
    What does your preview to external monitor from the AE timeline look like?
  • Andrew Yoole
    May 13, 2006 at 2:42 pm
    Two things to check:
    By default, imported standard def video will be interpreted with lower field first field order. As AE previews don’t display both fields of interpreted footage, you effectively only see half the resolution. The workaround is to turn field interpretion OFF while you work, then reactivate it at render time.
    Also, do you have aspect ratio preview activated? This is a low quality stretch which doesn’t look so good – turn it off when you don’t need it.
  • Marcelokron
    May 13, 2006 at 3:18 pm
    look like a crap, i get the same image with low def. on out put to my monitor through firewire…
  • Steve Roberts
    May 14, 2006 at 2:06 am
    If you are planning to move, rotate, scale, blur, or otherwise distort the footage, you should separate fields. Otherwise, you should not separate fields. Re-interpret the footage without separating fields. Leave it off. If you are then animating anything in AE and want to render fields, you should render fields then.
    I’ve found that if you separate fields on footage that will basically be unaltered (except for brightness or colour, maybe) you lose quality.
    Let us know if that works.
