Activity Forums Apple Final Cut Pro Legacy Quality loss in using “Scale” and “Replicate”
  • Quality loss in using “Scale” and “Replicate”
    Posted by Robert Eidschun on July 27, 2008 at 6:44 am
    In using Final Cut on my computer, when I use “Scale” on the Motion tab to scale a clip down in size, or when I apply the “Replicate” Filter, I get a substantial loss in quality, in comparison to what I get on another computer running the same version of Final Cut with the same settings, using the same clips, etc. The loss in quality manifests itself as jagged edges and pixelation.
    Of course, in comparing the output of Final Cut on my computer with that from Final Cut on the other computer, I look at those outputs on the same monitor, and ultimately, on a television attached to a DVD player, in which a DVD is playing, playing back the results from both instances of Final Cut.
    Once again, each instance of Final Cut is the same version, processing the same clips in the same way, using the same settings, etc. — only one such instance produces much better results. What could possibly be wrong? Some low level system problem on my computer, such that Final Cut on my computer is not using Quartz Extreme and OpenGL properly?
    I have checked my QuickTime Pro preferences, have checked the “Use high-quality video setting when available” box, etc.
    By the way, the differences in quality are obvious in the Canvas, even before rendering. But as I say, they are still there in the final “product”, i.e. DVD.
    Thank you.
    Robert Eidschun replied 18 years, 2 months ago 1 Member · 1 Reply
  • Robert Eidschun
    July 27, 2008 at 7:18 am
    Update:
    Deleted com.apple.quicktime.plugin.preferences.plist and QuickTime preferences, both located in /users/username/library/preferences, then restarted computer.
    Following that, deleted Final Cut preferences, OBJ cache and Prof cache files located in /users/username/library/preferences/FCP user data/
    Result: scaling down a clip using “Scale” on the Motion tab now works fine, without the loss of quality that was occurring previously. However, use of the “Replicate” Filter still results in the same loss of quality as before.
    Any suggestions would be appreciated. Thanks.
