Activity › Forums › Adobe Premiere Pro › Quadro 4000 and ATI 5770 on a Mac Pro
Posted by Phil Hawes on September 24, 2012 at 8:03 pmHello to all,
Is there any advantage or are there any known problems with putting the ATI HD 5770 graphics card in slot 1 and the NVIDIA Quadro 4000 in slot 2 of the Mac Pro 5,1?
My thinking is to maximize the Quadro 4000 for GPU acceleration in Premiere and After Effects CS6.
George Demetriou replied 12 years, 6 months ago 9 Members · 16 Replies -
Erik Lindahl
September 24, 2012 at 8:56 pmCan Premier Pro CS6 actually use a non-GUI-card for CUDA acceleration?
Phil Hawes
September 24, 2012 at 9:05 pmNo, it can’t.
Only the Quadro 4000 has a CUDA driver.
The ATI card will be used for the displays.Since I posted this message I’ve been doing some tests which seem to indicate that the Quadro 4000 works better by itself without the ATI card installed.
Does anyone else have this experience?
Chris Borjis
September 24, 2012 at 10:15 pmThe quadro has to be the display card for Premiere to use it.
This is frustrating to those that want to also use it with DaVinci,
which wants the card to NOT be the display. -
Phil Hawes
September 25, 2012 at 4:22 pmAgreed. That is frustrating if you want to use Resolve.
I intend to learn Speedgrade since that apparently will be supported by NVIDIA.Regarding the combination of ATI graphics cards and NVIDIA graphics
cards on a Mac Pro, I also received the following reply from NVIDIA support:“The combination of a NVIDIA Quadro card and ATI HD 5770 graphics card would not be compatible as there might be driver conflicts as the drivers for the Quadro card and the ATI card are not unified.”
This might explain the problems I had in Pemiere with both cards installed: no playback and crashing.
Francois Driessen
September 25, 2012 at 11:58 pmI’ve been running the 5770 and a Q4000 for premiere without hassles…
MacPro 8core Wesmere. 24G ram.
OS 10.7.4
Latest Cuda driver 5.0.24 & Resolve9
Black Mgic DecLink Studio SDI. Latest driver. 9.6.4Got the 5770 in Slot 1 running 2 displays
Q4000 in slot 2. GPU only.
Then DecLink in 3 and CalDigit eSATA for raid.What problems are you facing exactly? What codecs are you working with and what’s you sequence codec?
Francois
FireTrigger Inc.
https://firetrigger.com -
Phil Hawes
September 26, 2012 at 3:07 pmI have several Mac Pros where I had both graphics cards installed.
Some of them have the exact configuration you have, same OS, same CUDA driver, minus Resolve and the Black Magic Card.I’m surprised you can put the Black Magic card in slot 3 since that is a slower x4 PCI slot.
The problems I had were not codec specific. But it started when I was working with a slightly larger than 2K image sequence file on a 1080 24p sequence. So I was asking Premiere to do rotation, image resizing, frame interpolation,and cropping. I had no playback.
With the ATI card removed, my playback problems were solved.
Perhaps it was not the card, perhaps there are other problems on that machine (RAM?) but as a precaution I have removed all ATI cards until I can test this out further.
If you run into any issues please post it on this forum.
Thanks for the response.
Gerry Curtis
September 26, 2012 at 7:20 pmHi There,
I am running Premiere 6.01 and Resolve with those 2 cards under the same configuration as Francois, it works fine for me.
Cheers,
Gerry
http://www.digitalkilnstudios.com
http://www.savasanafilm.com -
Cali Pvp
October 6, 2012 at 3:10 am -
Scott Reynolds
January 22, 2013 at 10:18 pmNice rig. Where are you getting the additional power from? I thought the 5,1 only had 2 additional power connectors for PCIe cards and the 5870 uses both?
Cheers,
scott -
Cali Pvp
January 29, 2013 at 4:43 amI was a little concerned when I first installed both cards. Well… very concerned…. But I’m glad I did it. I’ve been running both cards now for more than a year, almost two years without any problems. Knock on wood. As for the power, I bought a power adapter with to connections and ran one to the Quadro card and the other two to the ATi card.
