Activity Forums Avid Media Composer QT wont open Avid exported files
  • QT wont open Avid exported files
    Posted by Scott Davis on June 1, 2011 at 3:10 pm
    When I try to open a QT that was exported from Avid (1920×1080 DNXHD145) it will either never open; keeps saying “loading” or if it does it looks like every other scan line is missing. VLC opens the files fine as does QT on other systems. Avid is installed on the sytem so the codecs are there. Any thoughts?
    Avid 5.5.1
    Mac OS 10.6.7
    QT 10
    Scott Davis
    View Scott Davis's profile on LinkedIn
    Brendan Maghran replied 15 years, 3 months ago 4 Members · 4 Replies
  • John Pale
    June 1, 2011 at 6:44 pm
    You may have an old version of the avid codec installed. Avid made some major changes to make it smpte compliant. Download and install the latest and see if it fixes the problem.
  • Scott Davis
    June 1, 2011 at 6:53 pm
    I don’t think that is it. The codecs where installed when 5.5.1 was installed. It is a brand new system and had no other Avid codecs installed.
    Scott Davis
  • Scott Cumbo
    June 1, 2011 at 9:43 pm
    Did you try re-importing that QT back into Avid to check it?
    Scott Cumbo
    Editor
    Broadway Video, NYC
  • Brendan Maghran
    June 2, 2011 at 10:58 pm
    Or try playing in Quicktime 7 instead of Quicktime X?
    “Where that light source is coming from?”
    “The same place as the music.”
