Activity › Forums › Apple Final Cut Pro Legacy › QT refs from DPX files won’t play
Posted by Tom Von doom on June 24, 2009 at 5:02 pmI’ve digitized footage from HDCAM SR to DPX files. When I bring the QT refs into the project and try to play them, I get the spinning beach ball. Files play fine in Quicktime. I have a Kona 3 card, a 4TB fibrechannel array, a 2 x 3gHz dual core Intel Xeon with 12 gigs of running FCP 6.0.3 in OS 10.4.11. I’ve trashed prefs, installed the latest AJA drivers, changed the expansion slot link width. Any ideas?
Gary Adcock replied 17 years, 3 months ago 3 Members · 7 Replies -
Aaron Neitz
June 24, 2009 at 5:46 pmUsing the AJA QT wrapper? Or GlueTools?
Might be time to upgrade to Leopard actually.
Tom Von doom
June 24, 2009 at 6:04 pmDo I have to use the DPXtoQT Translator? The AJA VTR exchange creates QT refs. In the AJA documentation, it says you can work with the QT refs, but I suppose they wouldn’t have the QT translor utility if it wasn’t necessary. I don’t have Gluetools.
Aaron Neitz
June 24, 2009 at 6:09 pmnever used the VTR exchange – the DPX to QT translator works though
Tom Von doom
June 24, 2009 at 6:28 pmI used the QT Translator. Same problem. Beach ball of death when I try to play the file. Very annoying. The files are big, but the drives are fast enough. Does this stuff usually work for you? Maybe I’m missing something. Thanks for trying to help.
Tom Von doom
June 24, 2009 at 6:54 pmOK, I figured it out. There was a mismatch on the Kona output. I adjusted it, and now, it works! Thanks for helping me think it through. I love this site!
Gary Adcock
June 25, 2009 at 2:43 am[Tom Von Doom] “Do I have to use the DPXtoQT Translator? “
Yes you do.
it takes about 10-15 secs per DPX folder.
“The AJA VTR exchange creates QT refs”
and if you move the original file location the QT Ref files can generate errors, use the translator to always create new ones.gary adcock
Studio37
HD & Film Consultation
Post and Production WorkflowsCheck out
https://www.aja.com/kiprotour/Inside look at the IoHD
https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php -
Gary Adcock
June 25, 2009 at 2:44 am[Tom Von Doom] ” Beach ball of death when I try to play the file. Very annoying. “
what are you playing the files from? This sounds like the drives are not fast enough.
gary adcock
Studio37
