Activity Forums Apple Final Cut Pro Legacy QT Reference Files From FCP for PC playback?
  • QT Reference Files From FCP for PC playback?
    Posted by Bill Olafsen on August 7, 2008 at 3:09 pm
    Is there a way to provide a QT Reference (Not a Self-Contained Movie) that can be played on a PC that has QT Pro. My Final Cut and PC are sharing a SAN. The SAN is seen as a local drive by both the Mac and the PC. The SAN is a Third Party not XSAN. I have tried various methods. No matter what codec or method I try, the PC will see the QT but only present the Audio and not the Video.
    BILL
    Kevin Monahan replied 18 years, 1 month ago 4 Members · 6 Replies
  • Walter Biscardi
    August 7, 2008 at 3:18 pm
    [Bill Olafsen] “Is there a way to provide a QT Reference (Not a Self-Contained Movie) that can be played on a PC that has QT Pro. “
    No, the PC will not be able to properly reference the material. In fact, I don’t believe it’s possible to make a Reference file that will work on anything but the computer that creates it.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Bill Olafsen
    August 7, 2008 at 3:53 pm
    The QT reference I created on 1 Mac with FCP will play on a totally different Mac, without FCP installed, as long as it also sees the SAN as a local drive. Also this process in reverse, create QT reference on PC with AVID and it will playback on a Mac as long as both machines see the SAN as a local drive. All the machines in this test are loaded with the last release of QT PRO. Any Ideas?
    BILL
  • Kevin Monahan
    August 7, 2008 at 5:16 pm
    Which codec are you using? If it’s DVCPro HD there is a possibility that PC users can see it if certain software is installed.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Bill Olafsen
    August 7, 2008 at 6:45 pm
    I have selected various codecs for my “Reference” QT including DVCPRO-HD. I just double checked the path again using the DVCPRO-HD codec with the same results. QT Pro will play the audio from the reference file on the PC but will not play the video. What software might you be thinking of?
    BILL
  • Michael Hancock
    August 7, 2008 at 7:04 pm
    Raylight for the PC will let you read FCP DVCProHD files on a PC. You can download the demo here:
    https://dvfilm.com/raylight/decoder/index.htm
    If it works, it sounds like it would be worth buying.
    Michael.
  • Kevin Monahan
    August 7, 2008 at 7:05 pm
    It’s from Calibrated. Noah Kavner blogged about it here: https://blogs.creativecow.net/node/542
    These guys make it possible to view DVCPro HD on any computer. The only other way is to install FC Studio on every computer and that isn’t even possible with PCs.
    They also have cool software to edit the native MXF files.
    Check it out.
    Kevin Monahan
