Activity Forums Apple Final Cut Pro Legacy Qt player problems
  • Qt player problems
    Posted by James Ander on May 15, 2008 at 8:02 pm
    Hi everybody
    I have a problem with playing HD mov files on my g5. I am opening them up in QT player but it won’t show. I don’t have FCP installed and I know that it’s captured in FCP. anyone have any idea abut codec downloads or something like that?
    J
    James Ander replied 18 years, 4 months ago 3 Members · 6 Replies
  • Russell Lasson
    May 15, 2008 at 8:06 pm
    It’s likely that the files are compressed as DVCPROHD or ProRes. Maybe even a form of HDV or XDCAM. May of these codecs only come with FCP, so if you don’t have it installed, you can’t play the file.
    If you open the file in QT and get info about the file, it should say the codec that it was compressed as, even if you don’t have the codec. So, what does it say by the video section of get info?
    -Russ
    Russell Lasson
    Kaleidoscope Pictures
    Provo, UT
  • James Ander
    May 15, 2008 at 8:58 pm
    This is what is says
    DVCPRO HD 720p60, 960 x 720 (1248 x 702), Millions
    that’s the only thing, not codec and not required codec.
  • Russell Lasson
    May 15, 2008 at 9:08 pm
    Well the only way to get access to the DVCPROHD codec is by installing software like FCP that has the codec. It’s not publicly available.
    -Russ
    Russell Lasson
    Provo, UT
  • James Ander
    May 15, 2008 at 9:43 pm
    I have premiere on a pc with premiere installed, do you think that will work to preview the files?
    thanks for the response by the way.
  • Ed Dooley
    May 15, 2008 at 10:36 pm
  • James Ander
    May 15, 2008 at 10:51 pm
    awesome I am gonna check it out right away
