Activity › Forums › Adobe Premiere Pro › QT file size limitation when rending movie out of Premiere
  • QT file size limitation when rending movie out of Premiere
    Posted by Navarone on December 29, 2006 at 4:09 pm
    Does anyone know if there is a file size limitation for rendering QT movies out of Premiere? I have one work area that gets to 99.9% and then generates a “Unknown Error” – “Error compiling movie”, the movie is uncompressed and ends up being 4.3gb. I have plenty of disc space so thats not an issue and I can form the same time line render a different work area and not inncur a problem
    What is man that you should be mindful of him?
    Peconius replied 19 years, 9 months ago 4 Members · 3 Replies
  • Blast1
    December 29, 2006 at 7:54 pm
    Are you using FAT32 or NTFS?, FAT32 has a 4gig file limit.
  • Mike Velte
    December 30, 2006 at 11:55 am
    There is a 4 GB file size limit (regardless of file system) on many legacy codecs that are not Open DML. Try rendering in smaller chunks.
  • Peconius
    December 31, 2006 at 10:49 am
    I have the same problem I
