Activity Forums Maxon Cinema 4D QMC GI creates odd light patterns on mildly complex objects
  • QMC GI creates odd light patterns on mildly complex objects
    Posted by Jareb Coupe on May 10, 2015 at 12:56 pm
    I had to bail on Irradiance Cache for a GI method (reasons described in different post), which of course leaves QMC.
    I have noticed an issue in multiple scenes with QMC, and was wondering if anyone else experienced the same, or knew what the problem was.
    Specifically, on objects with fine/sharp/deep angles, where the illumination is trying to reach a thin area, it does some odd shading. I can’t tell if it’s light that’s not supposed to be there, or occlusion that’s not supposed to be there.
    Check out the pic:
    I’ve also seen it occur with the default ‘baseboards’ with the new House Builder (NitroMan), as well as a the canned bed spread (Blanket 02) in the Visualize content.
    I’ve tried:
    – Removing Ambient Occlusion
    – Removing all textures
    – Reducing the scene to one light source (sun)
    – Removing secondary GI method
    – Increasing Accuracy of QMC to 90%
    – Playing around with Discrete Area/Sky Sampling
    – Simplifying extruded splines in hearth
    – Other Phong options
    – Other spline ‘Type’ and Intermediate Points settings
    What am I missing?
    Here’s a version of the image with less compression.
    Adam Trachtenberg replied 11 years, 4 months ago 2 Members · 3 Replies
  • Jareb Coupe
    May 10, 2015 at 1:11 pm
    Something else worth mentioning: in lower light, the issue is accentuated. Also, I get the sense the pattern moves from render-to-render.
  • Jareb Coupe
    May 10, 2015 at 2:10 pm
    And a shot of the baseboards I mentioned:
    This may be a scale issue. I’m working in Inches, and a lot of these errors occur in the smaller/thin objects. Also, the pattern is a giveaway. Will investigate further.
    Hobbyist level. Used C4D since R14. Now on R16.
  • Adam Trachtenberg
    May 10, 2015 at 3:53 pm
    You’ll probably need to increase the sample count. In the GI general tab, set samples to “custom sample count” and bump samples up until the artifacts start to clear up.
