Activity Forums Apple Final Cut Pro Legacy Qmaster won’t run properly
  • Qmaster won’t run properly
    Posted by Tom Matthies on March 16, 2011 at 12:24 am
    Seems to be the day for Compressor problems…
    I cannot get Qmaster to run properly any more. If I can even get the cluster to show up in Compressor, it will give me an error message
    “An internal error occurred:Apple Qmaster File Agent not Found”
    A quick look in the Activity monitor shows all the cores showing up as “Not Responding”. Also it indicates that the CompressorJobController is not responding as well as the Qmaster Task Service, qmasterqd and the contentController.
    And I’m getting a message in the Activity Monitor that coreaudio is not responding either.
    I’ve tried using Compressor Repair to no avail.
    However, if I use a Compressor Droplet (I have MANY!) the activity monitor shows activity on all eight cores and the compression proceeds at a rapid pace.
    It seems the only way to access all the cores is through a Droplet.
    Qmaster has always had a little VooDoo in it but…sheesh…
    Tom
    Compressor 3.5.3, Leopard 10.5.8, 2×2.8Ghz Quad-Core Intel, Quicktime 7.6.9
    E=MC2+/-2db
    Bob Pierce replied 14 years, 8 months ago 4 Members · 3 Replies
  • Mark Laslo
    March 24, 2011 at 5:46 pm
    Hey Tom
    I’m having a similar issue. Did you find any solution?
    Mark
  • Erik Mickelson
    September 27, 2011 at 8:48 pm
    Just started getting this. I have successfully used quick clusters in the past. This massage is a first for me.
    Share function does not work either.
    I have reset background processing. Reset sevices. Made a new quick cluster.
    Nothing works.
    I will try a restart. First things last right?!
    CrippleBook Pro 2.3Ghz i7, 8GB ram, SLeopard 10.6.8, FCPStudio 3, QT 7
  • Bob Pierce
    January 19, 2012 at 1:27 am
    I’m having the same problem. I’ve seen lots of posts all over the internet and no solution. Did you guys sort it out? I just did a full uninstall and reinstall of FC Studio and it’s still doing this.
    Bob Pierce
    Director of Photography • Editor
    http://www.lightstreamassociates.com
