Activity Forums Apple Final Cut Pro Legacy Qmaster setup
  • Posted by Jesse Austin on June 21, 2011 at 3:12 am
    Hello out there…
    Ok can someone help me out please? What is the proper way to set up Qmaster and how do I know it is working correctly? The comp is a 2×2.66 6 core Intel with 20 gigs of ram. So I have heard that you will setup QuickCluster with services, check share and managed. Since there is 20 gigs of ram you would select 19 instances leaving 1 gig for background stuff to continue.
    So up in the menu bar I see the Qmaster icon with all 19 instances listed. Now when I start compressing a video file in Compressor after selecting the QuickCluster I just created, I never have seen all 19 lite up green, only a few will show being captured. Why is this?
    Any help would be nice…
    Jess
    Rafael Amador replied 15 years, 3 months ago 2 Members · 3 Replies
  • Rafael Amador
    June 21, 2011 at 10:42 am
    [Jesse Austin] “Ok can someone help me out please? What is the proper way to set up Qmaster and how do I know it is working correctly? The comp is a 2×2.66 6 core Intel with 20 gigs of ram. So I have heard that you will setup QuickCluster with services, check share and managed. Since there is 20 gigs of ram you would select 19 instances leaving 1 gig for background stuff to continue.
    So up in the menu bar I see the Qmaster icon with all 19 instances listed. Now when I start compressing a video file in Compressor after selecting the QuickCluster I just created, I never have seen all 19 lite up green, only a few will show being captured. Why is this?”
    I thinkthat the top number of instances you can set, is the same of the processors/cores you have.
    The RAM works different, normally is recommended 2GBs RAM per processor/core.
    rafael
    http://www.nagavideo.com
  • Jesse Austin
    June 22, 2011 at 3:00 am
    Hey,
    What do you mean 2gigs per core? Since there is 12 cores I should be set up with 24gigs of ram?
    Jess
  • Rafael Amador
    June 23, 2011 at 9:31 am
    Right.
    That’s the minimum recommended RAM.
    rafael
