Activity Forums Apple Final Cut Pro Legacy Pyro AV Link Audio Latency
  • Pyro AV Link Audio Latency
    Posted by Jenny Mettee on June 22, 2010 at 1:28 am
    I have a VCR which I have hooked into the Pyro with RCA cables and then the Pyro going into my Mac Pro with FireWire. I turned off “abort capture for dropped frames” and my capture settings are non-controllable device, and DV NTSC 48Khz Advanced. I now can record without it stopping but the audio latency is horrible. Any suggestions?
    Also, when I play back what was captured, it will play the audio, with the latency, but if I stop the clip, I cannot hear any audio unless I play the clip from the beginning.
    I have 16 gigs of ram and the ATI Radeon HD 3870 video card and FCP 7.0.2
    Rafael Amador replied 16 years, 3 months ago 2 Members · 6 Replies
  • Rafael Amador
    June 22, 2010 at 9:56 am
    Hi Jenny,
    What kind of hard drive are you using?
    rafael
    http://www.nagavideo.com
  • Jenny Mettee
    June 22, 2010 at 2:02 pm
    All internal drives. The fcp file is on a separate drive than what I am capturing on. FCP itself is running on a separate drive too. So total 3 different drives.
  • Jenny Mettee
    June 22, 2010 at 7:50 pm
    Or are you asking about brands of hardrives? Then all Seagate Barracuda 1.5tb 7200’s, except the Western Digital Hard drive which is my OS X and FCP application drive that came with the machine.
  • Rafael Amador
    June 23, 2010 at 2:29 am
    No Jenny, I was wondering if you were using any USB or FAT-32 formated HD.
    rafael
  • Jenny Mettee
    June 23, 2010 at 2:31 am
    Nope all OS X journaled drives.
  • Rafael Amador
    June 23, 2010 at 5:08 am
    With internal HDs and your RAM this shouldn’t be happening.
    No clue Jenny, but whenever I have this kind of issues (glitches, slow performance..) I start by running Diskwarrior.
    90% of the FC problems comes from a poor System maintenance.
    rafael
