Activity Forums Sony Cameras PXW-X70 not outputing 1080p50 over SDI
  • PXW-X70 not outputing 1080p50 over SDI
    Posted by Mladen Erjavec on February 24, 2020 at 11:35 am
    As the title says. I bought two of these cameras specifically to be permanently plugged into the mixer in the large hall, and 1080p50 is simply not working. If I select 1080i or 720p signal shows up just fine.
    For the reference, signals are fed to the switcher AV MATRIX PVS05615, and it receives other sources 1080p without problems, and outputs the same to BlackMagic SDI Distribution from where it goes to screens.
    Is there something obvious that I am missing?
    Both cameras came with Firmware 3.03 out of the box, that appears to be the latest one.
    Mladen Erjavec replied 6 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
