Activity › Forums › VEGAS Pro › Putting together rendered clips without rendering again?
  • Putting together rendered clips without rendering again?
    Posted by Milad Mohammadi on September 8, 2011 at 9:44 pm
    Hi!
    I have almost finished my first real attempt of a video project. My project is a video message, which is aimed personally to a numerous of people.
    The first part of the video is the same for everyone (the longest clips as well). The second is the same, with the exception of one bit in the middle, where it is specific for each person. The third part is specific for each person.
    Is it possible to render the shared parts, and then put them together/attach them with the person specific parts? Without losing quality?
    I do not want to render the same clips, over and over again. Is there any software, free or not?
    Nigel O’neill replied 15 years ago 3 Members · 2 Replies
  • Mike Kujbida
    September 8, 2011 at 9:50 pm
    If you’re using Vegas Pro, save each section with a specific project name (e.g. intro.veg, milad-middle. veg, milad-end.veg).
    When it comes time to render, import the necessary veg files, drop them on the timeline (this is called nesting) and render to the desired format.
  • Nigel O’neill
    September 9, 2011 at 2:47 am
    You could also render them out separately and then use DVDA to create separate discs or discs with unique chapters, with each chapter being a rendered out file from Vegas.
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
