Activity Forums Adobe Premiere Pro Putting selected clips in the project window
  • Putting selected clips in the project window
    Posted by Mike Strasser on May 2, 2006 at 10:58 am
    Hi there,
    I want to put a clip in the project window because I will need it often.
    Because it would be fine to easily drag it in the timeline whereever I like.
    In the premiere pro 1.5 this does not work. What do I have to do?
    Respectively how do you handle a clip that you want to reuse often?
    Is there a clipboard or something?
    thanks mike
    Steven L. gotz replied 20 years, 4 months ago 3 Members · 4 Replies
  • Mike Velte
    May 2, 2006 at 11:03 am
    Set In and Out points in the Source monitor and then drag that to the Project window, renaming as needed.
  • Mike Strasser
    May 2, 2006 at 12:49 pm
    It seems that thing is cursed. *g*
    It does not work.
    I selected in and out point but when I drag it out of the timeline
    into the project window: The cursor still changes to blocked symbol.
    I should be able to do this with the select tool, should
  • Mike Strasser
    May 3, 2006 at 1:37 pm
    Any Idea? Anybody?
  • Steven L. gotz
    May 3, 2006 at 2:10 pm
    Try a new project. If you have a clip in the source monitor, you must be able to grab it from the middle of the frame and drag it into the project window. Either that, or you have an installation, problem, or a problem with drivers.
    Steven
    http://www.stevengotz.com
