Activity Forums VEGAS Pro putting pictures in a slideshow come out blury
  • putting pictures in a slideshow come out blury
    Posted by Kyle Fishel on May 18, 2010 at 8:49 pm
    I’m trying to make a sideshow in sony vegas 9 and every time I put pictures in that are high quality the quality drops so that everything is fuzzy. Does anyone know how to fix this?
    Mike Kujbida replied 16 years, 3 months ago 5 Members · 14 Replies
  • 14 Replies
  • Mike Kujbida
    May 18, 2010 at 9:37 pm
    What’s the size of the images (in pixels, please)?
    What are you viewing them on to say that they’re blurry?
  • Kyle Fishel
    May 18, 2010 at 9:42 pm
    The size differs but mainly it is 1932×2576 in pixels and its blurry in the preview screen as well as when I render it. There are also black bars on the sides of the pictures on some. Not because they are too tall I have tried adjusting it using the event pan/crop and the bars are always there. Thanks for the help.
  • Al Bergstein
    May 18, 2010 at 10:25 pm
    JPEG or TIFF? I’ve gone with TIFF format as they usually end up rendering better in video.
    Alf
  • Mike Kujbida
    May 18, 2010 at 11:02 pm
    If the final destination is a DVD, then a TV monitor/TV set is where you should be judging quality and nowhere else.
    Unless you’re doing deep zooms on the images, they’re too large in size and can potentially cause problems such as flicker.
    You didn’t say where you’re from but SD (standard definition) NTSC is 720 x 480 and PAL is 720 x 576.
    The usual recommendation is to not go more than 2X this size (1440 x 9860 // 1440 x 1152) unless you’re doing deep zooms on the images.
    I use IrfanView (it’s free) to do a batch resize on all my images before I bring them into Vegas.
    To get around the black bars on the images (it’s a square vs. rectangular pixel issue with stills being square), click the first one, open the Pan/Crop window, right-click and select Match Output Aspect.
    The image will now stretch to fill the frame (i.e. no black borders).
    Exit Pan/Crop and Copy the first image.
    Click image #2, go to the last image and Shift+Click it.
    This selects all of them.
    Right-click on any image and select Paste Event Attributes.
    If you’ve followed these steps, all your images will now be stretched to fill the frame.
    Be advised that Paste Event Attributes will paste any and all corrections (such as colour correction) that you made to the first image so this is something that I highly recommend doing as a first step.
    BTW, I never recommend TIFF as that particular format makes a “call” to QuickTime for each and every frame of the video.
    JPEGs are OK and PNGs or TGAs are even better.
  • Bob Peterson
    May 18, 2010 at 11:04 pm
    The black bars simply mean that the photos are not properly cropped to fit your selected video output. The vertical dimension does not seem excessive, so it could be that your source is not as good as you think it is. The other possibility is an error in the project settings.
  • Bob Peterson
    May 18, 2010 at 11:10 pm
    I continue to scratch my head about why QT is called to handle tifs. Surely Sony knows that tifs are an Adobe format? Are they simply not interested enough to read and process the image themselves? Apple and Adobe are not on the best of terms these days. BTW, tif is my preferred format unless I am going to Vegas. Then I must convert to PNG.
  • Kyle Fishel
    May 18, 2010 at 11:17 pm
    The photos are cropped to fit that’s what I am telling you. I know about if the photo is too tall or too wide it will make black bars like you see on dvds. I am saying some have them and they wont go away no matter the amount I zoom into them
  • Mike Kujbida
    May 19, 2010 at 12:05 am
    That’s why you have to use the Pan/Crop – Match Output Aspect method I mentioned.
  • Bob Peterson
    May 19, 2010 at 3:38 am
    Since QuickTime is opening tif files, I would not count on superior quality. I prefer PNGs which, like tifs, are a lossless compression format. Vegas likes PNGs, JPGs, or Targa.
  • Kyle Fishel
    May 19, 2010 at 4:02 am
    Alright thank you I followed your steps and it fixed the bars on the sides but added some on the bottoms. I’m just not going through manually and selecting 4:3 in the pan/crop settings to the ones with the bars on the bottom now.
