Activity › Forums › Apple Final Cut Pro Legacy › Putting both 4:3 and HD 16:9 on time line
Posted by Suzin Daly on July 29, 2008 at 6:53 pmNew to final cut pro, anything I need to do special when using both 4:3 and HD 16.9 on the same time line? It’s a public access TV and the show is edited in FCP, interveiw is shot 4:3 but many of the movie shorts aired standard 16:9 and HD etc.
Jared Smith replied 17 years, 5 months ago 4 Members · 9 Replies -
Don Greening
July 29, 2008 at 7:19 pmThe recommended workflow will depend on what kind of picture aspect ratio you want for final output. Is the program going to be 4:3 or 16:9? Standard def or HD? What version of FCP are you using?
– Don
Suzin Daly
July 29, 2008 at 7:25 pmFCP 6.0.4 final out put – public access and everything is 4:3 stand def
Don Greening
July 29, 2008 at 7:42 pmOKay. You can drag first 16:9 clip into an SD 4:3 timeline. If the sequence is still empty FCP will ask if you want to change the sequence settings to match the clip settings. Just say no. FCP will automatically letterbox and pillarbox the clip. Double-click the clip in the timeline to load it into the Viewer. Make sure “Image and Wireframe” is active. In the Viewer drag the corner of the clip until the top and bottom of it fills the 4:3 frame. This will create a centre-punch of your widescreen clip.
Hit Cmd-C to copy the clip’s attributes to the clipboard. Drag the rest of your widescreen clips into the sequence, highlight them all and hit Option-V to paste the first clip’s scale attributes onto all the other highlighted 16:9 clips.
Hope this helps speed things up for you.
– Don
Don Greening
July 29, 2008 at 7:57 pmLet me know how things work out. After you’ve pasted the attributes you can still slide individual widescreen clips from side to side in the timeline to keep important bits in frame.
– Don
Alessio Gemma
July 30, 2008 at 4:59 pmHello,
I’ve the same problem… I’ve both SD 4:3 material and HDV 16:9 and my target is a SD 16:9.
I use a SD 16:9 sequence: I drag the SD 4:3 clip in the timeline and then I refuse the changing of sequence setting.. I double-click the clip to open it in the viewer, I upscale the 4:3 clip to reach the 16:9 bounds, obtaining a full widescreen clip.
Now, I copy (CMD-C) the clip attributes (with the Viewer selected), I drag another clip in the sequence, I select it and I paste (ALT-V) the settings copied previously… but it doesn’t work… the clip remains 4:3…
Where I mistake?
Regards,
Alessio -
Don Greening
July 30, 2008 at 8:05 pm[Alessio Gemma] “I select it and I paste (ALT-V) the settings copied previously… but it doesn’t work… the clip remains 4:3… “
When you hit “Option-V” to paste the attributes a window will come up with all the different parameters available for pasting onto your destination clip. In your case, where you want to change the scale and/or motion parameters you need to make sure there’s a check mark next to those attributes before you click OK.
Have a look at Martin Baker’s excellent tutorials:
https://www.digital-heaven.co.uk/podcast/
View his 2 podcasts entitled Pasting Attributes 1 and 2.
– Don
Alessio Gemma
July 31, 2008 at 9:39 amGreat!
It’s really what I was looking for! 🙂
Thanks Don!
Alessio -
Jared Smith
April 22, 2009 at 7:41 pmI started a project and put my HD footage in the timeline first, then I captured some of my SD footage and drug it into the timeline… of course it was smaller and the sides of the HD footage were playing behind it and able to be seen… So, should I start over and do the SD clips first and then decline the choice to change the preferences when I add the HD footage? Is that the best option?
