Activity Forums Adobe Premiere Pro pushing tracks back
  • pushing tracks back
    Posted by Bodybuildingbs on January 29, 2006 at 10:02 pm
    How do I push both tracks back ie audio and video to the right to insert another clip in PPRO 1.5? I have tried all the selections tools but am missing something obvious. Thank you.
    Mike Velte replied 20 years, 8 months ago 3 Members · 2 Replies
  • Craig Howard
    January 30, 2006 at 12:12 am
    A number of ways and most are fundamental to NL editing. Some depends where you are “getting” the new clip from. eg ,. Source Window or Project Window.
    Heres a couple of ways:
    Drag a new clip into a timeline position using a modifier key – in this case “CTRL”
    You can insert your clip using Insert Command or Insert Keys or Insert shortcuts eg “,”
    Note that inserting usually requires that you set the track as the “Target”
  • Mike Velte
    January 30, 2006 at 12:17 pm
    The clutsy method might use the track select tool modified with the shift key to push “everything” to the right.
