Activity › Forums › Apple Final Cut Pro Legacy › Purposely downgrading an image from HD to SD
  • Purposely downgrading an image from HD to SD
    Posted by Michael Sullivan on December 31, 2011 at 5:49 pm
    Hello all,
    I am working on a makeup project shot in HD that we all think would look better if I downgraded the image to SD as you can see all the pours, blemishes, cracks in the lead models face. The amount of retouching is enormous.
    The end result will be a quicktime movie for the web
    I theorized that reducing the videos to SD would make the viewer see less than half the pixels, Trouble is, after downconverting, I’m not seeing much of a difference.
    Videos are starting at 1080p at 23.98 PRORES, 16×9
    My goal was to produce an SD mov at the proper 16×9 ratio.
    I first tried to downconvert through Compressor and that wasn’t working…then I actually made a DVD, and MACRIPPED/MPEGStreamclipped that back into a mov and other than the brightness shifting a little, there was no difference.
    Now I’m theorizing that one needs to view on a TV to see the difference.
    Can anyone point me in the right direction?
    Thanks, Mike
    Shane Ross replied 14 years, 9 months ago 2 Members · 1 Reply
