Activity Forums Apple Final Cut Pro Legacy Purple Line Running Down the Right Side of my Footage
  • Purple Line Running Down the Right Side of my Footage
    Posted by Brien Longobardi on September 15, 2011 at 8:02 pm
    Hey Guys; Has anybody ever had a purple line running down the right side of your footage? OK here is what’s going on I am working on a feature documentary some footage HD and some SD I took the SD footage and converted the footage to DVCPro HD 960×720 in Compressor. Some of the tapes / video file has a purple line running down the right side of footage in the source and timeline window but when I look at the orginal file it is fine. I also notice that the composition is off from when it is in the source window compared to the orginal it looks like it drifted alittle left so I went to the motion tab in the source window and on the X-axis parameter typed in 1 and it is gone and the original and the source window are an identical match. Any help would be highly appreciated and thanks in advance
    Brien
    Brien Longobardi replied 14 years, 11 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    September 18, 2011 at 5:17 pm
    Sounds like some sort of rounding error in the resize. I think if it looks OK otherwise, I’d crop it out and move along…
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Brien Longobardi
    September 19, 2011 at 12:22 am
    That was my thought I just wanted to double check. Thank you for your response
    B
