Activity Forums Adobe After Effects Purge All shortcut in CS5 using a MacBook Pro/laptop keyboard with no numeric keypad?
  • Todd Kopriva
    April 29, 2013 at 2:57 pm
    Are you really purging all of your caches so often that you need to use a keyboard shortcut for it? If so, that is a sign of a rather serious problem.
    After Effects team blog
  • Mike Imam
    April 29, 2013 at 3:27 pm
    Indeed I am. No serious problem, but I work on the road a lot, so I’m stuck with my maxed out 8GB of ram in my MacBook Pro. I do frequent RAM previews which eat up a ton of memory, so I purge after every few previews. Make sense?
  • Todd Kopriva
    April 29, 2013 at 4:19 pm
    It sounds like what you want to purge is just the image caches, not use the broader “All” command. You are throwing away the baby with the bathwater.
  • Mike Imam
    April 29, 2013 at 5:00 pm
    That could work too – is there a shortcut for that on a non-numeric keypad laptop keyboard?
  • Todd Kopriva
    April 29, 2013 at 5:02 pm
    Nope. No shortcut for that at all.
    If you want a shortcut for that, please make a feature request:
    https://www.adobe.com/go/wish
  • Mike Imam
    April 29, 2013 at 5:39 pm
    Thanks for confirming. I made the feature request. I should probably ask Jeff Almasol to add it to the KeyedUp script as well.
