Activity Forums Audio Purchasing a Sound Devices 702 – What else do I need?
  • Purchasing a Sound Devices 702 – What else do I need?
    Posted by Eric Strom on March 5, 2009 at 6:03 am
    I am Purchasing a Sound Devices 702. What else do I need besides a 4GB CF card? What mics and cables should I buy. I am thinking 2 wireless and 1 shotgun mics but wihch ones will give me the most bang for my buck? A recommended product list of what I should buy would be great. My head is spinning looking at all the options. Thanks!
    Ty Ford replied 17 years, 2 months ago 4 Members · 9 Replies
  • 9 Replies
  • David C jones
    March 5, 2009 at 4:59 pm
    Hi Eric-
    What are planning on using the 702 for? What’s your budget? Money no object?
    Need a little more info be recommendations can be made :o)
    Regards,
    Dave
  • Ty Ford
    March 5, 2009 at 8:32 pm
    Hello Eric and welcome to the Cow Audio Forum,
    Do you not need timecode? If you need timecode, make sure you get the 702T.
    You need a mixer and mics and cables and headphones.
    The Sound Devices 302 mixer mates well with the 702. I think Sound Devices also has a good mixer to camera cable if you just want to go staright to camera. They also have other accessory cables, as needed.
    Wireless Mics: the Sennheiser G2 series wireless or Audio Technica 1800 are as low as I’d go. The Lectrosonics are a notch up and Audio Ltd are at the top.
    Boom mics; you’ll want a shotgun (mostly for exterior) and a hypercardioid (mostly for interior).
    In descending order from best to not as good.
    Shotguns: Schoeps CMIT, Sennheiser 416, Sennheiser, MKH 60, Rode NTG-3, Sanken CS-3e
    Hypercardioid: Schoeps cmc641, Audix SCX-01 HC, Oktava MC012 w/ hyper capsule.
    Headphones: Sony MDR7506.
    Wind gear: Rycote
    Boom: K-tek
    Boom suspension mount: Rycote InVision
    Regards,
    Ty Ford
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Watch Ty play guitar
  • Eric Strom
    March 6, 2009 at 5:28 am
    Do I really need one with timecode? Won’t I be fine if I just use a clapper and sync up the audio with the video?
    Will a $1300 mixer really make that much of a difference?
    Presuming my budget for all this is $3000 what should I get? That automatically rules out the mixer.
  • Ty Ford
    March 6, 2009 at 5:51 am
    Hello Eric,
    Let’s take ’em one at a time.
    Clapper will work, sure, but with time code and a video camera with time code a syncing becomes a lot easier.
    I have the 442 mixer and 744T 4 track recorder. In a pinch, the 702 and 702T can be used without a mixer, but you can’t mix very well because the knobs on the 744 and 702 aren’t really designed to follow dialog. The 302 mixer allows for three simultaneous inputs. The 702/702T only has two.
    If you went to the store with soup money and found out you were hungry for meat, what would you do.
    Regards,
    Ty Ford
  • Eric Strom
    March 6, 2009 at 7:03 am
    Okay so if it is just a matter of making it easier then that’s fine. I have never had an issue with syncing up to a clapper. I’ll be able to tell if it is out of sync as long as the audio doesn’t drift.
    Okay, so I agree that the mixer would be wonderful but I was planning on recording each separately anyways and mix in post especially since it’s that much more money i may not be able to afford.
    I would eat soup instead of becoming a male prostitute to afford the meat. 🙂 I see your point really, but there has to be line drawn for each individuals budget.
  • David C jones
    March 6, 2009 at 3:40 pm
    Again, what are you planning on recording? This can make a big difference in what gear you might want to get. I have the 702T because I needed timecode for double-system. In my opinion, if you’re doing ANYTHING with video/film, timecode can be a big help. If you’re just recording “wild sound” or music, or anything where syncing it to picture isn’t needed, then a non-timecode recorder is fine.
    As far as a mixer goes, I agree with Ty that you need something. Those volume knobs on the recorder are not really designed (or meant) to be ridden like faders on a mixer. You might try looking for a used mixer on some of the audio store websites or even ebay. I also agree with the equipment list Ty recommended.
    Regards,
    Dave J
  • Eric Strom
    March 15, 2009 at 12:42 am
    Okay, I will have to try to find some finacning to afford all this. Do yo have specific Lectrosonics mics you would suggest? There are a ton to choose from on their site.
  • Bill Brock
    June 29, 2009 at 11:59 pm
    Ty, you really put the Sanken CS3e below the NTG3? I’m curious why when everyone raves about it? Thanks!
  • Ty Ford
    June 30, 2009 at 12:57 am
    Hello Bill,
    It was a list of mics. I don’t think it was in a specific order, but I think the NTG-3 is less prone to RF than the CS-3e. That’s based on anecdotal info. Although I have demoed both, I haven’t done both at the same time. I can say the NTG-3 is slightly wider than the 416 and is lighter on the bottom.
    Regards,
    Ty Ford
