Activity › Forums › Adobe After Effects › Puppet Tool Problem
  • Puppet Tool Problem
    Posted by Colin Kennedy on November 8, 2011 at 8:07 pm
    The puppet tool itself is working fine but when I do any camera movements, it appears that the image the puppet tool is applied to is being chopped up from the path of the pinpoints. Does anyone know a solution to this problem?
    Phil Lebeau replied 14 years, 8 months ago 3 Members · 2 Replies
  • Tudor “ted” jelescu
    November 8, 2011 at 8:39 pm
    I think you can get rid of this issue if you animate the 2d layer wiyh Puppet Tool and then nest that in a comp (pre comp) and make that comp layer 3d.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Phil Lebeau
    January 6, 2012 at 4:01 pm
    I was having the same issue. But my layer is 2d. I have a arm with a pointing finger… I need to have the position of the arm come in from the right side of the screen and then by using the puppet tool I was going to move a finger to point. But When I set the points and move the arm out of the frame, the puppet tool does not go with it.
    Any thoughts would be great!
