Puppet Tool and HD format quality of video is poor
The puppet tool produces poor quality video for HD when camera is zoomed into the video.
I have an character created in PS that is being animated in AE with the puppet tool. The animation is pretty complicated and includes many layers and pre-comps. The original size of the PS character is 1440×1080 to match the AE size comp. settings and layers. No proxy files are used to create the puppet tool animated video.
SPECIAL NOTE: The problem ONLY appears after render… the preview window/view does NOT show this degradation even when at full resolution (hmmm… will “Save RAM Preview” do a better job than rendering it normally in the render queue?).
Solutions I have tried (but, didn’t work):
1) …increased to max number of triangles.
2) …tried to monkey around with the camera options (…making sure Depth of Field was off, messed with Focus Distance, Bur Lvel, etc.)
2) …tried to precomp and then render…using NUMEROUS various video codecs… in fact I spent a whole day looking for a render solution using ever combination of codec I could using AE, Avid and Prem. Pro).
3) …tried various combination of layers to see if that made a difference (incl. combination of opacity levels to see that helped – yea, I am getting desperate).
4) …eliminated all other effects (to narrow it down to the puppet tool as being the problem).There appears to be no blur option with the puppet tool…. unless, there is something I am missing.
As it stands, the puppet tool and rendered to HD doesn’t work very well with camera zooms.
See attached pics to see comparitive loss of detail between using the puppet tool (i.e., w puppet) and no puppet tool used (i.e., no puppet). SORRY BUT UPLOADING OF PICS FROM THIS SITE DID NOT WORK…. BUT, BASICALLY USING THE PUPPET TOOL MAKES IT LOOK PIXALATED AND WITH JAGGED EDGED LINES…
