Puppet Pin Preventing Preview
So I haven’t done a lot of Puppet Pinning in my 15 years of AE work, but the last 2 days, I’ve used it on 2 projects, and have had the same issue each time. At some point, it gets tired of me making adjustments to the key frames or to other layers (I haven’t found a rhyme or reason yet), it prevents AE from previewing the first frame of a pinned layer or beyond.
Basically, I hit 0, and I get to watch right up to the first frame of that layer, then we go to the beginning of the comp and watch it again to that point (as if I’ve set the end point to the frame before the pinned layer).
I can frame by frame through that section, but I see none of the animation. I can try to force it by setting the beginning point at the beginning of the layer, and I get that message about “AE needs more than 1 frame blah blah blah,” so it’s just refusing to render.
I’ve tried restarting, clearing cache, just letting it sit there and think about things for a while, none of it fixes my issue.
My solution. Throw out my pinning and redo it. Works great (until it doesn’t again). Luckily I’m only doing a little pin work, so I’m not murdered by the redo, but it’s irritating. And it’s happened on both animations, so this doesn’t seem to be a one time thing.
Running a MacPro 2019
3.3 GHz 12-Core Intel Xeon W
256G of ram
AMD Radeon Pro Vega II 32 GB
AE 23.0.0 (build 59)
