Activity › Forums › Adobe After Effects Expressions › Pump Up The Jam
  • Posted by Laszlo Kovacs on January 27, 2007 at 2:55 pm
    Hi!
    I’d like to re-create this:
    https://www.youtube.com/watch?v=Lap_Nd6P0W4
    When she’s rapping (at the beginning), the words are displayed behind her, synchronised with the rhyme.
    This could be done by putting each word on its on layer, and arranging them to line up with the rhyme, but that would be a tedious work.
    Is there any other (simpler) way to achieve this via expressions, assuming that I have the proper keyframes where each word should come up?
    Thanks in advance
    Mike Clasby replied 19 years, 8 months ago 3 Members · 3 Replies
  • Mylenium
    January 28, 2007 at 1:12 pm
    Unless computers have become sentient over night and actually understand the menaing of words (which I doubt) – no. not sure why you’d want to overcomplicate this simple setup. The words pop in with hard cuts, so timing is simple and multiplying them can be doen easily using motion Tile or similar effects (you may need to pre-compose).
    Mylenium
    [Pour Myl
  • Mike Clasby
    January 29, 2007 at 9:44 am
    OK, this isn’t too bad. An expression to choose the right word, controlled by a slider, and Motion tile for the grid like Mylenium suggested.
    First, with the Text Tool, put a letter (I used “A”) in the middle of the screen. I made it 100 pixels (for the Bell Gothic Std font) which seems to work when you use the motion tile later.
    Add a slider Control, Effect>Expression Controls>Slider Control.
    Then add this expression to the Source Text, twirl down, Alt Click the Source Text Stopwatch, then paste in the expression:
    s = “honesty,integrity,loyalty,compassion,empathy”;
    n = Math.floor(effect(“Slider Control”)(“Slider”));
    s.split(“,”)[n]
    Put your song lyrics or the text you want on the screen in place of the “honesty,integrity,loyalty,compassion,empathy” in line one of the expression. Like “pump,up,the,jam”,
    as many words as you want. now when the slider is on 0, you get “pump”, 1 = “up”, etc.
    So to get the grid of letters, Effect> Stylize>Motion Tile. And to get a 5×5 grid as in your example, setting for my text were (note: My comp was 640×480, change numbers below for different comp):
    Motion Tile
    Tile Center: 321, 214
    Tile Width: 20
    Tile Height: 17
    Output Width: 100
    Output Height: 110
    Note: If your choosing numbers out of order, for example you want to choose “Pump” again, or 0 on the Slider, but if follows a 3 for “Jam”, you need to select the keyframes and make them Hold Keyframes, otherwise you’ll flip through the words on you way from 3 to 0 on the slider.
    This expression was hacked from a Dan Ebberts expression, again.
    Oh, yeah, if the words are way differnt in size, numbers of letters, you could be in trouble with the motion tile, keyframes needed.
    Good luck.
  • Mike Clasby
    January 29, 2007 at 9:49 am
    Note: If you put a number on the slider larger than the number of words you have in the expression, you’ll get “undefined” as text (it’s an error). So you might want to Right Click the blue slider number, then set the Min and Max Range for your slider. Remember you need the 0 as that is your first word.
