Activity Forums Adobe After Effects pulling matts from color matts out of VRAY
  • pulling matts from color matts out of VRAY
    Posted by Ryan Duff on August 1, 2012 at 10:21 pm
    I have been given a colored matt pass out of VRAY with 4-5 objects. in order to pull an alpha of each object, i have been doing a linear color key on an object and using that as a track matt. The problem is that some of the colors are close enough that i need to squeeze the tolerance pretty tight. The edges get very chewy and pixelated.
    Is there a different technique i should be using?
    Darby Edelen replied 14 years, 1 month ago 2 Members · 4 Replies
  • Darby Edelen
    August 1, 2012 at 11:59 pm
    What colors are being used?
    Darby Edelen
  • Ryan Duff
    August 2, 2012 at 4:15 pm
    here is a frame of the animation that im dealing with.
    Ryan Duff
    ryan@ryanduff.com
    http://www.ryanduff.com
  • Ryan Duff
    August 2, 2012 at 4:17 pm
  • Darby Edelen
    August 3, 2012 at 2:39 pm
    Tough to say exactly what would work for that image. If the keying effects aren’t doing it then you could try to create a matte using Color Correction > Channel Mixer set to Monochrome. For a mixed color like cyan you’d have to try and increase the blue and green contributions while reducing the red. Even then this may only get you part of the way since a lot of these colors do look fairly close.
    Darby Edelen
